  1. When i try to export to dv-avi with adobe premier 1.5, i seem to get vertical lines from top to bottom in certain scenes. This is only when i output interlaced video, not when i use my 24p option on my cam. Its a bit strange i figured it might be a codec problem, but i heard someone else talking about the same problem, so if you know please let me know, thanks.
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi t-h-e-w-h-o,
    You might also find an answer over in the forum at http://www.wrigleyvideo.com/videotutorial
    Good luck.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
