This may not be a S2D question, but I have been archiving some older 4:3 tv series, six episodes per DVD. It's going good until this. One episode in particular encodes at the wrong aspect ratio. What is an "AVI PAR" and can I force S2D to ignore this? Thanks in advance for any help.
According to the logs (boldface by me):
=================== AV Details ===================
File Size: 201 MB
file=E:\Secret.Photo.avi
FormatName=avi
Num_Frames=44580
DurationInSecs=1487
Duration=00:24:47.4
VideoCodec=mpeg4
Width=544
Height=352
Standard=NTSC
BitRate=1134
AudioStreamCount=1
Audio1SampleRate=44100
Audio1Codec=mp3
Audio1BitRate=128
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
AVI2MPG: 3832kbs Full-D1
12:56:17: Looking for AVI PAR...
12:56:17: video:696988kB audio:40738kB global headers:0kB muxing overhead 2.234441%
12:56:17: AVI has PAR 16:9. VTS will be 16:9
Using user defined matrices
Pass 1/2: Processing Secret.Photo.avi
12:56:18: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
All the other assets are similar to this: (S2D does not find an AVI PAR, and it encodes OK)
File Size: 202 MB
file=E:\Secret.Building.avi
FormatName=avi
Num_Frames=44779
DurationInSecs=1494
Duration=00:24:54.1
VideoCodec=mpeg4
Width=544
Height=352
Standard=NTSC
BitRate=1135
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=128
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
14:02:48: Looking for AVI PAR...
14:02:48: video:695794kB audio:40672kB global headers:0kB muxing overhead 2.252019%
Pass 1/2: Processing Secret.Building.avi
14:02:49: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
Well some avi files - mpeg4 - have non square pixels. So S2D tries to take this into account. Usually an avi has 1:1 pixel aspect ratio and so if the dimensions are 4:3 the dvd will be 4:3 or if the dimensions are 16:9 then the dvd will be 16:9...
BUT if the pixel aspect ratio is 16:9 then the DVD is 16:9 too.
If this is in error for this one file i will need to see a sample to correct the algorithm.
When i get back from my travels (28th) i can take a look at a sample...SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thank you for your quick response. I created a 5mb sample with your utility, but I was unable to upload to your FTP server-"connection time out" Perhaps your server is down or more likely my FTP xfer programme is set up badly.
In the meantime, I reserched and found a utility called mpeg4modifier from here: www.moitah.net that purports to alter the AVI PAR without affecting the original asset. I looked at both files and they were the same i.e. square pixels.
Success! I ticked the 4:3 NTSC button, saved it as another file, and S2D then encoded it propetly.
Do you still want to see the original? -
Well if you have it sorted then no - i have a raft of emails to plough through at the moment. BUT if it happens again then yes i would like to get it resolved.
(thanks for your patience)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Unable to play asset in preview window
By gstewart in forum Newbie / General discussionsReplies: 2Last Post: 3rd May 2010, 19:04 -
Asset Play in SVCD2DVD
By PerryM in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th Aug 2009, 12:47 -
blank asset menu
By anakin1312 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 05:21 -
ffmpeg.exe preventing upload of asset
By daz72 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Aug 2007, 03:27 -
Remove asset button?
By coldracerx in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Aug 2007, 21:13
