Hi,
I wish to enquire what would be the best raw codec output mode which a brooktree capture card should be set to before its compressed by Huffyuv or another codec.
I have the following available :- RGB24 which consumes a lot of data a second YUY2 and YV12
According the the datasheets for the BT878 chip, data is upsampled to RGB24 from 4:2:2 so RGB24 would be a waste of time due to no gain in quality and very high bandwidth.
So which is better and what do people use YUY2 or YV12?
<font size=-1>[ This Message was edited by: ironwood321 on 2001-12-28 17:07:13 ]</font>
YUY2 is a good choice if you want to compress with Huffyuv. YUY2 works with most codecs.
YV12 is downsampled to 4:1:1, so it has a bit less color precision, and it's not compatible with many compression codecs. At high frame sizes (like 720 pixels per line) the loss is negligible, so YV12 is still a viable alternative.
Generally you can find the best match by choosing a format and trying it with the codecs you want to use. Some versions of the PicVideo codec, for example, give a better picture from RGB24 than they do with YUY2--apparently a codec bug. So always give it a test run!
-tacosalad
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 11:25 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
raw dv
By matriplex in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 18th Aug 2008, 19:56 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
