    Oct 2005
    Is this a true statement: When using software filters, original source must always be re-encoded --> re-encoding leads to loss of quality.
    If true, I'm trying to understand why so many opt for software filters.. Is it b/c the 'enhancement' of the image when using software filters is worth the loss in quality?? (sorry, if I'm using incorrect terms).
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    The statement is true, but the degree of loss can be negligable and not visible when watching the video at normal speeds on normal TVs. It depends on what filters you use and what goals you're trying to accomplish.
    Only you can decide if the efforts are worth it.
    Buy My Books
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Only time I use filters is when I have to reencode anyway.
    /Mats
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'll split this up:
    True.
    That's not a hard and fast rule in my book. If your source is of questionable quality, then it's normally more apparent. If you've got an excellent quality source, then it is far less apparent. Also, there is the case of an umcompressed source, you run some filters on it, and output uncompressed. I fail to see any possibility at all that this re-encode degrades quality.
    As above, filters can only "tweak" - they're not miracle workers. I firmly believe that the right filters at the right time can improve the visual quality. Otherwise, as you say, why would people filter if they're not enhancing the video at all ?
    If in doubt, Google it.
  5. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Filters were designed originally to work with a high quality video source such as HuffyUV or PICVideo MJPEG or DV where you capture in that high quality format then need to convert (compress) down to something else (such as MPEG-2 DVD spec).
    So in the encoding process why NOT add filters ... if they are needed?
    - John "FulciLives" Coleman
  6. Member vhelp's Avatar
    Mar 2001
    New York
    Because I am in the middle of an exhaustive RGB and YUV image
    research and discovery quest, I feel I have my own set of
    opinions to share on this
    Well.., IMHO, this is true. re-encoding always leads to some
    level of quality loss.
    But, maybe "loss" is not the right word to use here
    (at least at this time in my dealings) I would rather replace the
    word "loss" with "detail", but..
    The reason why I feel this way, is dependant upon the type of
    *method* used during the pixel manipulation. And there are many
    methods of pixel manipulations. Though most are one variation or
    another of "averaging" pixels on a number of images. So lets use
    this "average" as a theory and take a short tour of its use..
    The moment you take away from the original source, is the first acts
    of quality loss or detail.
    Ok. For instance, say you have a pixel who's R/G/B values are a certain
    set of numbers.. ie, 255 / 255 / 255
    ( or, to get the true color of a certain pixel, you would perform the
    following component calculation: 255*255*255 = 16,581,375 )
    and then you apply an average on this pixel against another nearby pixel,
    who's R/G/B values are a certain set of numbers.. ie, 100 / 90 / 16
    following component calculation: 100*90*16 = 144,000 )
    When speaking of "averaging" (as an example) the user would take the
    R/G/B components each, (that's why I separated them w/ an "/")
    and perform the averaging.
    In the example above:
    255/255/255 and 100/90/16 (or 16581375 and 144000) average computes
    would be:
    (R=255 + R=100)/2 = R=177
    (G=255 + G=090)/2 = G=172
    (B=255 + B=016)/2 = B=135
    Thus, the Averagel_New_Pixel_TrueColor_Value = 4,109,940
    ( or, broken down into their respective components: 177/172/135 )
    The point of this excercise (or theory) is to show how *ONE* pixel
    changed would result in a perspective of quality loss or detail.
    Thus, once you change one pixel's value (not mentioned, hundreds of'em)
    you change the original sources detail, or consider there to be some
    level of quality loss.. depending upon once's perspective of "loss"
    fwiw noting here, the above could just have easily been used inside an
    YUV color space.
    However, there (IMHO) another side to this quality loss theory.
    But, I feel it crosses the boarder of this topics subject.. at this
    time.
    -vhelp 3759
    Oct 2005
    OK, I have a better understanding now.. Thanks.
    So what is consensus here on which method is "superior" for transferring VHS/LD to DVD?? Using all hardware (full frame TBC, color corrector, detailer, DVD recorder, etc.) or capturing to pc and using software filters?? Assumption: Source material is NOT high quality.
    I'm doing xfrs of old home videos for friends using a JVC DVHS, full frame TBC and a JVC DVD recorder, then editing on pc, authoring.. I just want to make sure I'm not "cheating" them on quality.
