hope someone can help. I'm trying to convert single xVid (avi) file to DVD using DVDSanta and when I select the AVI file it seems to some sort of analysing and gives me an error that says "Audio Stream not Supported"
Results 1 to 11 of 11
MP3 VBR audio is your problem. One cure is to drop the Xvid into Virtualdub Mod and extract the audio as a WAV, then use that audio and the original video to encode. You will run into it often with Xvid/Divx off the net. A guide:
https://www.videohelp.com/forum/viewtopic.php?t=280779 -
..or just use either The Film Machine or AVI2DVD to do your conversion to DVD format. Both are freeware & work quite well. I have found DVDSanta to be quite buggy, picky, & has zero tech support behind it.
Thanks for all the helpful information.
I tried the conversion using DivxtoDVD and everything was great, good audio/video conversion, it displayed the subtitles when played on the computer but the subtitles do not show when playing on standalone dvd player. Its a Korean movie and so I need the Subtitles. So close but yet so far. -
have you tried pushing the "subtitle" button on your player/remote while watching the movie?
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 20:24 -
Error Converting to Xvid
By Davop in forum DVD RippingReplies: 2Last Post: 23rd Jan 2010, 06:06 -
Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??
By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 07:44 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 10:23 -
Converting Xvid avi's to dvd always fail
By sosnowski in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2008, 16:36
