Hi all,
I need help in converting a DVD with stills and clips mixed (it contains
still pictures with background music and a couple of video clips). I've
tried to convert but I have lost synchronization of audio and video.
I would appreciate any help.
Best,
AS.
Please post your methods & software used & where sync goes off... IOW a bit more info.
Usually you're just stripping audio/video, converting each, & putting back together, so only issue would be if you account for any audio delay set in the DVD. If you've got stills as std m2v, shouldn't be a prob., but if the stills use some sort of hold command (play this frame & hold for *x* time, it'll get a bit more interesting.
Thanks for reply.
I used the tools and technique explained in "How to Guides" section (DVD to VCD). When I play final VCD, I see no still images, it starts with
video clip playing music of other chapter (the one with still image).
I guess I have to extract stills, video, audio first then combine them
one by one. Which tools can help me out with that stuff ?
In this case I need to find out a way to create a VCD with
still pictures and music playing on the background but each photo must
match with a particular audio clip (just like a powerpoint with music).
Thank you one again for any feedback. -
PLEASE try post in correct forum. dvd to vcd is no dvd authoring. moving you.
what guide??? post a link.
Problem with mkv to DVD conversion
By LoafingOaf in forum ffmpegX general discussionReplies: 0Last Post: 27th Oct 2009, 06:46 -
problem with conversion from DV-AVI to DVD
By obadvw in forum Video ConversionReplies: 1Last Post: 24th Jun 2009, 17:08 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 02:22 -
DVD to ipod Conversion Problem
By Cirone328 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2008, 11:29 -
WMV to DVD or VCD Conversion
By MannyNoela in forum Video ConversionReplies: 9Last Post: 6th Feb 2008, 10:22
