Am using Clonedvd2 and am happy with the results.
The problem i have is i have a number of small files (20 minutes each) which i am converting from avi to dvd using Win AVI.
But when i launch clonedvd to burn it i can only burn 1 at a time is there any way i can burn multiple clips one after another using either Clonedvd or WinAVI
I don't know about WinAVI, but I don't think so in CloneDVD2. Are you just wanting the files to run one after the other or do you want a menu structure?
If you don't want the menu use DVD Shrink in Re-Author mode and add the clips consecutively. If you would like the menu try TDA, it's payware but there is a fully functional 30 day trial, and is very easy to use. -
If I understand correctly, you basically just want to get the 20 min segments on a DVD.
One approach would be to string the avi files together in V/Dub or using Avisynth, then encode.
Another approach would be to use an authoring prog, as e404pnf suggested. There's the free DVD author GUIs, muxman, & several apps with trials. You can also pick up usually OEM versions of software dirt cheap online, including a few entry level authoring prog. A lot depends on if you want menus, how customized you want them, that sort of thing.
Can't clone DVD with CloneDVD2
By Navop in forum DVD RippingReplies: 4Last Post: 6th Mar 2012, 11:36 -
clonedvd2 problem...
By ironmanDD in forum DVD RippingReplies: 0Last Post: 29th Jan 2011, 20:29 -
CloneDVD2 - worth buying with AnyDVD or not?
By trimicada in forum DVD RippingReplies: 14Last Post: 23rd Dec 2009, 11:52 -
CloneDVD2
By pepegot1 in forum DVD & Blu-ray WritersReplies: 2Last Post: 10th May 2008, 17:46 -
cant get audio comentary off of some dvds with clonedvd2
By pigtails2 in forum DVD RippingReplies: 0Last Post: 22nd Feb 2008, 16:55
