Hi, I was just wondering how to check if a DVD+RW is finalized? Should Nero do it automatically? Does it do it automatically for DVD+R's? If it isn't finalized, is there a simple way with WindowsXP, nero or something else to do it? Sorry for the basic question, tried searching but couldn't find this anywhere. Dean
OK. I have a portable player that only plays DVD+R's created by Nero, not DVD+RW's. Was wondering if finalizing was the problem. Any other fundamental differences? DVD's created from my DVD recorder work fine.
but in my case, dvd+rw's work when created with my dvd recorder. so it's picking stuff up. i'll have to keep experimenting i guess.
Don't use Multisession when burning in Nero. That will give you a RW disk with a finalized single session.
thanks. i'll have a look for the multisession option when i get home. i'm using the dvd-video option, not burning rom software because i want to convert avi files first. can't remember seeing it but will have a look. maybe i should put the dvd files to the hard drive first and then burn them using burning rom.
Finalize DVD-R, is this possible?
By chiyoaiki in forum DVD & Blu-ray RecordersReplies: 35Last Post: 19th Dec 2016, 13:49 -
finalize DVD
By bobaumichedu in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2011, 14:59 -
Is there a way to not have to finalize a DVD after burning?
By EagleW in forum Authoring (Blu-ray)Replies: 3Last Post: 27th Jan 2010, 16:56 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Finalize DVD-R PROBLEMS
By wswingsze in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Sep 2007, 22:12
