Hi,
Recently I bought a Samsung Home Theatre (Model: Samsung HT-UP30).
It is playing DivX files (avi files) only of size smaller than 1GB.
Is it a limitation of player? Player Manual doesn't specify any such limitations.
Is there any hack/tool to make the player play big avi files?
Or Any good tool to split huge avi file to multiple smaller avi files without compromising quality.
Regards,
Jeyakumar CK
1 GB is a limitation of the ISO9660 file system, which is typically used for data CD/DVD. If you have files > 1 GB, the burner app is using something like UDF (maybe without letting you in on the secret), which the player might not handle.
Use VirtualDub to split AVIs.
/Mats -
Actually, the limit is 2GB's. Same limit for old type avi's. A 1GB limit is just weird. Haven't heard of it with any other players.
Correct - my mistake. Maybe some connection with 1 GB max VOB size?
/Mats -
When I first got my Liteon LVD 2002 Divx/DVD player I found it wouldn't play files over 1GB on ISO disks. Eventually I figured out that finalizing the disks increased that to 2GB (the limit for the ISO file system) and enabled long filenames.
The UDF file system supports files up to 4GB. I haven't had occasion to test that on my player.
Playing Media Files on Samsung TV Through the USB Port
By twentyroses in forum Newbie / General discussionsReplies: 13Last Post: 5th Sep 2011, 07:01 -
Playing Ripped Video_TS Files on Samsung BluRay Through DLNA
By Satchmo in forum DVD RippingReplies: 0Last Post: 12th Jun 2011, 22:31 -
Question how to make srt/avi subtitles bigger when playing in DVD player
By jimdagys in forum SubtitleReplies: 6Last Post: 24th Oct 2008, 00:10 -
How can I take a 1gb AVI file and make 10 x 100mb files?
By tyders in forum EditingReplies: 4Last Post: 5th Dec 2007, 10:15 -
Samsung HT-TX75 not playing my Divx & Xvid files
By danimaltron in forum DVD & Blu-ray PlayersReplies: 7Last Post: 19th Nov 2007, 20:02
