first question: i'm using winavi video converter 7.1. I don't know why the sound doesn't match the video, the speech is faster than the action. wondering which options should i check or shouldn't check.
second quetion: Since there is so many ways to convert rmvb to avi now, i'm wondering which software is the best to convert rmvb to avi whitout losing the quality of images and sounds.
third question: which software allows you to convert severals rmvb to avi at once?
A big thanks to anyone who will answer to my questions![]()
1) winavi probably doesn't understand RMVB's variable frame rate. Few conversion programs do.
2) EO Video will work but the program is slow and has black level problems. Recent versions of AVISynth work well.
https://forum.videohelp.com/viewtopic.php?t=289872
3) Don't know. But you can convert them individually (all with the same settings) and join them together later with VirtualDub.
Convert rmvb to AVI
By pchan in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 05:09 -
rmvb -> avi again :evil:
By leovst in forum ffmpegX general discussionReplies: 2Last Post: 28th Mar 2008, 04:32 -
rmvb to mpeg/avi
By pcb in forum Video ConversionReplies: 3Last Post: 26th Jan 2008, 07:35 -
help with rmvb to avi?
By fruitpassion in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 18:46 -
A New Way To Convert RMVB to AVI
By RMVBMASTAPRO in forum Video ConversionReplies: 2Last Post: 27th May 2007, 18:41
