Any suggestions?! I have the WinTV PVR 150 from Hauppauge and I can't seem to get the PVR 150 IR Blaster to work. I've got a Scientific Atlanta Explorer 4200 box. It's not specifically listed in the IR Setup.
This seems weird to me - I thought IR needs to be in direct sight of the receiver in order to change a channel?! I covered up the whole front of the cable box with a hat and the remote still changed the channel.
You would need to block it with a solid object, such as a book or magazine.
Google is your Friend -
I tried blocking the whole front of the receiver with my arm. I guess I had some showing because it still changed the channel.
Bitrate problem - PVR-150
By m0dts in forum LinuxReplies: 4Last Post: 14th Dec 2009, 14:47 -
How do you setup the ir blaster for the hauppauge hd pvr 1212?
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Aug 2009, 10:42 -
PVR-150 poor tv quality
By kaptwan in forum Capturing and VCRReplies: 3Last Post: 21st Aug 2008, 16:15 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppauge PVR 150 compatibility with my OS
By GangstaRap in forum Capturing and VCRReplies: 11Last Post: 14th Mar 2008, 11:03
