  1. Chrissyboy,
    I had started svcd2dvd making a dvd out of some divx files and my computer crashed. After rebooting, I went to open up S2D and it would never respond. I closed and opened it about 3 times, all with the same result, "Not Responding". Figuring that somehow the program got corrupted, I downloaded the latest version from your website and installed. It made me go through the whole registration process again (This is a PITA,by the way), when I finished and clicked the registar button, nothing happened. It just stood there and looked at me. I am not able to register now for some reason. Please help!
    Mark
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Drop me an email & I'll try to get to the bottom of this.
  3. Got my problem straightened out, thanks anyway Chrissyboy. I do have another problem though with a finished DVD. When playing the DVD files while on my harddrive with PowerDVD, everything displays correctly. When I burned this particular DVD, on the menu that I made, the default red select buttons are always visible and are offset by quite a bit. This was my first try at making a DVD with S2D and so when I was making my menu I tried pressing some buttons that I guess, I should not have and all four of my links got piled on top of one another and I could not seperate them, so I pushed "reset" and started all over again. This may have happened a couple times on this menu. That is the only thing I can think of that i may have done wrong. Has anyone reported offset select highlights as of yet? I am using the latest release.
    Thanks,
    Mark
