I have a panasonic GS-17.
I capture the DV with adobe premiere pro. In my camera I use the cinema option. So the par is 1.067 pal.
The capture file is ok, but the problem is then I edit it in adobe.
The picture is then too small. It looks to small even in the sample window.
Then I export it the picture dont fill out my widescreen tv.
It even does it when dont convert it in any way.
I have tried with 16:9 and 4:3 project but nothing seems to work.
What exactly is "cinema mode" on a GS-17? Is this just simple horizontally squeezed 16:9 in a DV frame? Or is it altering field sequence?
http://www.kiva.org/about -
I think two black bars is added. Simple as that.
But I am not sure.
Then I used pinnacle studio it worked fine. -
Low end Sony camcorders in wide mode "letterbox" the CCD but output full height with H squeezed. I'm not sure what Panasonic does. Normally DV wide project formats will unfold that correctly in Premiere and others.
Typical low end widescreen is like the left pane here.
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere Pro 2 Help
By slicebogey in forum EditingReplies: 6Last Post: 9th May 2011, 17:21 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 17:10
