the first week my burner was a bit quiet...Now every often....it will make buzzing sounds then quiets down again....Is this normal?
I did use a different type of disc...at first i used 8x disc and now im using 16x disc...my usb is 1.1 port..
Buzzing sounds seem normal and harmless enough by themself. But how did you get in your burner to make them? That's what I'd like to know.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
The "buzzing" you are referring to, is most likely just noise from the disc spinning at high speed.
Google is your Friend -
No, it's not good. That usually means the disc is wobbling a lot. What kind of blank media are you using?
How to make an HD DVD disc without a Blu-ray DVD burner?
By coody in forum Blu-ray RippingReplies: 11Last Post: 23rd Aug 2010, 12:30 -
Do they make bluetooth transmitters for normal audio sources?
By yoda313 in forum Off topicReplies: 0Last Post: 6th Feb 2010, 14:46 -
Does SATA make big difference for DVD burner?
By sdsumike619 in forum ComputerReplies: 6Last Post: 28th Nov 2008, 20:21 -
using a webcam, plus time-lapse software, to make a normal speed video..
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 27th Apr 2008, 02:38 -
How can I make my dvd burner overclock to a faster speed?
By goheadtry in forum Authoring (DVD)Replies: 7Last Post: 2nd Dec 2007, 20:11
