Is it possible to take the menu from a DVD and covert to a JPEG with the same resolution as the menu. It sounds possible but I can't find any information as usch to confirm this or how to go about doing this. Any info welcome.
Cheers, Anthony
Load the menu VOB in VirtualDubMod, and save a frame, I think.
/Mats -
Cheers, I'm on a university computer at the moment so will give that a go when back home. Also is it possible to extract the audio from the menu using virtualdub.
Yes, use the same app. Snapshot function is under the Video menu, Snapshot source frame. It will save as bmp, tga or png, but you can always convert to jpg later.
To extract audio, Open the Streams list under Streams. You can either demux (you get the audio in the format it is) or save as wav.
/Mats
Help putting jpeg on a dvd!!
By ksorvick in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 15:02 -
how to retrive jpeg image from unfinalized DVD-r
By newtonraj in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2009, 05:42 -
How to author a HD DVD slideshow from TIFF/JPEG files?
By Voges in forum Authoring (DVD)Replies: 6Last Post: 25th Aug 2008, 02:15 -
JPEG --> DVD case cover
By vanquish42 in forum MediaReplies: 27Last Post: 26th Dec 2007, 16:09 -
Capture JPEG Screen Caps From DVD
By philly33flyers in forum DVD RippingReplies: 10Last Post: 25th Aug 2007, 12:48
