Hi,
I have two Xvid movies wich I am unable to play on my dvd/divx-player.
For the first one, it's because it uses quarterpixel. I wish to reencode this movie, without this option but with everything else the same. What program should I use for this (and how to use it, I'm not a pro?
For the second movie, I just have to downscale the resolution. Again, what program should I use?
Thx in advance
Results 1 to 10 of 10
Haven't used it, can't vouch for it, but it says it can do what you want. AVI ReComp
Read my blog here.
I've tried this program, along with others, but everytime I get the error "Statsfile not found" and "invalid sample format".
I got this error in Avi recomp, vdubmod and tmpgenc 3.0 express.
So I don't know what causes this error. Has anyone a clue? -
Corrupt download ?
You could try to repair it with Divfix or Divx Repair, but more than likely things won't change.Read my blog here.
I believe you can get the 'statsfile not found' error if your encoder is set for multiple passes and you try to do a one pass encode. The first pass creates the statsfile and the second uses it to improve compression. Check the encoder settings.
I have another question
Where in virtualdubmod can I choose a resolution? Or do I have to set it in the encoder properties (xvid). I've searched a lot in both but didn't find anyting. -
I am also having the 'statsfile not found' error, but I am trying to do a 2-pass encode? Any ideas on what could cause this?
For a 2-pass encode the encoder needs 2 (or more) passes. During the first pass it examines the video and creates a file full of statistics about each frame. During the second pass it uses that statistics file to determine how best to allocate bitrate to meet your average bitrate requirement.Originally Posted by KroZ
You get the "statsfile not found" error when that statistics file can't be found at the start of the second pass. This might be because you didn't perform the first pass (so the file was never created), you performed the first pass but had a invalid location for the statistics file, or you deleted the statistics file between the two passes.
Can I change the pixel aspect ratio in an x264 AVI without reencoding?
By Calidore in forum Video ConversionReplies: 24Last Post: 16th May 2018, 17:24 -
Need to convert h264 avi to mp4 without reencoding, help?
By chupacabra24 in forum Video ConversionReplies: 2Last Post: 30th Oct 2011, 12:02 -
how to change aspect ratio (PAR) in AVI without reencoding
By deejay.2001 in forum Video ConversionReplies: 1Last Post: 25th Sep 2010, 10:33 -
Add a watermark to .avi x Reencoding
By dexter30 in forum EditingReplies: 21Last Post: 8th Sep 2009, 21:42 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 20:56
