I have a older video on a vhs tape..Used to have sound but now I only hear a snipet of sound when it starts..then no sound..anyone have a clue on how to get the sound to come back or what happened to it
You might try playing with the tracking buttons.Originally Posted by scustalow
I do believe the audio track on a VHS tape is at the bottom half, so it's usually the very first to go if you store your tapes lying down(same orientation if inserted into VHS player)
I remember hearing that you should store your tapes on end to prevent this audio corruption from happening. Not sure exactly though of why it happens, does the tape get demagnatized or what?
If this is the case, then you probably will never get your audio back.
But of course as listed above, make sure of tracking and try another VHS player.
vhs video capture bad sound
By lulu15 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2011, 21:59 -
Sound doesn't convert using AutoGK
By Looler in forum Video ConversionReplies: 6Last Post: 25th Sep 2010, 22:40 -
mpg with sound that doesn't play
By sivodsi in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2010, 09:38 -
Why New Music Doesn't Sound As Good As It Did
By MeDiCo_BrUjO in forum Off topicReplies: 5Last Post: 12th Jul 2007, 18:44 -
ffmpeg doesn't reconize sound in video file.........
By ssj2_goha in forum Video ConversionReplies: 15Last Post: 18th May 2007, 16:38
