Results 1 to 9 of 9
    Nov 2005
    Brazil
    Hi folks,
    Do you know if is there out any encryption software that has a file encryption algorithm that can encrypt .VOB files for instance, without corrupt them so home player can read them.
    See you later,
    Aeolis
  2. Member e404pnf's Avatar
    Dec 2004
    Warmington on Sea
    Do you mean so that the movie can be played on a standalone but not copied?
    If so, NO. There are a couple of tricks that can slow someone down, but nothing that is 100% efficient, (if Hollywood can't do it what chance do have?)
    This has been discussed a couple of times before (once quite recently) try a quick search of the forum
    - e404pnf
  3. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    You mean something different than the software you plugged in
    this (click here) thread?
    Buy My Books
  4. Member e404pnf's Avatar
    Dec 2004
    Warmington on Sea
    though the name looked familiar
  5. What are these tricks you are talking of:
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    There's one: CSS. And we all know how well that works...
    /Mats
    Nov 2005
    Brazil
    Hi folks,
    Yes e404pnf I mean some software designed to encryption because that software that I mentioned in that post does a lot of other kind of stuff but doesn’t do the .VOBs encryption. And videopoo you are PERFECTLY right: everybody talks about tricks but nobody explains them. Please came on and talk about that tricks. Thank you videopoo you are right.
    See you later,
    Aeolis
    Nov 2005
    For the degree that css helps, I think Encore can add it. As all you're going to do is make it more difficult, & so hopefully not worth it, what if you encoded video with chapters not in order, then used playlist to sort it out? DVDLab docs I think discuss way to use serial numbers, which might protect ifos a little bit.
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    We already have; https://forum.videohelp.com/viewtopic.php?t=223640
    Everybody talks about stickies but nobody reads them
    If in doubt, Google it.
