Hello there i hope you can help me, my post covers several discussion groups so please forgive me if this is on the wrong board.
Here is my dilema. I am about to buy a panasonic pv gs 400 probably a pal system camera as i will be moving back to europe in the next couple of years.
i have numerous ntsc vhs tapes that i would like to put on dvd but am not sure what is the best way to go about it. I understand that certain cameras allow you to use them as the analog to digital decoder but i don't know whether it would work with a pal camera, i mean would the result be pal or ntsc data? Do you think it would be easier to buy a seperate video decoder and use that for the vhs conversion? Would that also convert my pal dv to ntsc when captured to the pc? Does tmpgenc read both pal and ntsc data and if i'm not mistaken it does not convert from one to the other? therefore i would have to use a seperate method.
I apologise once again for the awlwardness of this post any help is greatly appreciated, thankyou.
regards scotstrength
so do you think that i could still use the pal video camera as the analog to digital converter would the data still be in ntsc or pal format?
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 22:08 -
Capturing NTSC VHS tapes to PAL Final Cut...
By willed in forum Capturing and VCRReplies: 2Last Post: 22nd Jan 2008, 17:48 -
Capturing PAL VHS and DVDs to NTSC DVD
By joelkranz in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 17:11
