Hi,
I have attempted to burn movies downloaded from my camcorder using Nero6.3.0.0, but to no avail. I have successful burned home movies on DVD before, but since my pc was rebuilt recently I have been unsuccessful.
First attempt failed as I did not have the right codec, and I had to download from Indeo.ligos. I have since downloaded gspot to identify the codec type. I have also upgraded Nero to Nero 6.6.0.18, but no luck.
I have used Windows Movie Maker, Ulead video studio 7 basic, and Video presenter 2.0 to capture the movie. I have tried to export these in a format that Nero expects, but all options have been limited to either AVI or MPEG.
When I try to burn the above with Nero express it expects bup, vob or ifo file types, and attempting to burn the avi or mpeg file it responds with “The current compilation file is not supported by Nero Express. Would you like to open it in Nero Burning Rom instead?” Obviously, ROM burns the compilation, but I am unable to play it on my dvd player.
Any suggestions on what I’m doing wrong, or how to overcome the above problem
vKv
You seem to be missing the authoring step. It is the step that takes your compliant mpeg files and turns them into a DVD. I believe that NeroVision Express can do this - do you have it ?
Read my blog here.
Thanks for the prompt response.
No, i don't have it. As for authoring, i was under the impression Nero managed that prior to burning, and as i didn't have vision express previously, i'm now wondering how i managed to convert it previously..vKv -
You need Nero Vision Express. That will take your Avi or Mpg and basically author it ( Create DVD ) then you process your compilation wich creates the Video-TS file structure you then burn in Nero Burning Rom in DVD/Movie mode.
No DVD can withstand the power of DVDShrink along with AnyDVD!
help with burning home videos to dvd
By ppalacios2 in forum Newbie / General discussionsReplies: 4Last Post: 24th Mar 2010, 07:17 -
Best way to copy Home Movie DVD
By quxote in forum Authoring (DVD)Replies: 3Last Post: 18th Jul 2009, 03:27 -
Problems Burning Movie Files onto blank Dvds-RW disks
By tealmarlin in forum Newbie / General discussionsReplies: 35Last Post: 1st Jan 2009, 12:18 -
Authoring a DVD home movie
By vikasa in forum Authoring (DVD)Replies: 29Last Post: 30th Aug 2008, 18:29 -
problems burning movie file
By lynette00 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2008, 06:40
