Hi All,
I have a couple of queries regarding Divx/Xvid Play back.
1. from time to time when i play a file i notice it will freeze during playback yet the file plays ok on my PC. Is there a program i can use to analyse .avi files for possible defects?
2. When i play a widescreen file i still get the 2 black bars. My TV and recorder are both set to 16:9. It looks like the file in rendered in 4:3 then the black bars are added Any ideas?
Will updating firmware fix any of these issues?
Flop
1. Virtualdub can scan for bad frames. Also, not all Divx encoding modes are supported by standaolne players. There are restrictions.
2. If the file isn't exactly 16:9 (1.78:1) or 4:3 (1.33), then you will get black bars. If it is between 1.33 and 1.78 you will get pillarboxing, or bars left and right. If it is greater than 1.78 (e.g. 1.85, 2.35, 2.40 etc) then you will get letterboxing (bars top and bottom). If you don't like it, use the zoom function to fill the screen, but cut off the ends.
If you want to understand why this happens, read this
http://widescreen.org/aspect_ratios.shtml
In summary, it is working as it should.Read my blog here.
my LG freezes on some divx/xvid playback as well, ive found that if i press stop when it freezes and play again it works again. try that. i also have a problem with progressive scan needing to be switched back and forth from on and off on certain things, anything like that?
DivX vs. H.264. vs. Divx HD: What best for playback on Philips BDP5320 ???
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 26Last Post: 21st Sep 2011, 05:50 -
Video conversion queries
By AussieTuca in forum Video ConversionReplies: 3Last Post: 16th Aug 2011, 20:01 -
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 21:42 -
Some plasma TV queries: Panasonic G10A plasmas OK for SD?
By rossnroller in forum DVB / IPTVReplies: 14Last Post: 28th Jan 2010, 18:01 -
Anyone know SQL queries?
By sdsumike619 in forum ComputerReplies: 3Last Post: 16th Oct 2008, 21:37
