i try to add a 300mb mpeg2 file to a dvd project with nero 7 but it came out to be 700mb, does anyone know why
Because Nero has reencoded it, possible changing the audio to LPCM. A little more detail might help us though. Are you just burning using Nero, or is a Nerovision project ?
Read my blog here.
yes it is a nero vision project. i converted .rmvb file to mpeg2 using winavi and i limited the output file to 300mb(minimum) the output file plays fine, and when i add the file onto the project it occupies over 700mb
NeroVision has decided, for whatever reason, that it wants to re-encode your project. Unless you can turn off this 'feature' there isn't much you can do while you continue to use Nero. It has always had a habit of doing this, going by comments from users frustrated by the same thing you are.
Read my blog here.
i have seen one dvd contain as many as 15 movie files the same length as the movie that im burning, any idea how this is being done
none of those encoder convert rmvb files i think, but ill try different encorder and burning programs to see wut i get. thanx for the help
If you search the forums you will methods that do. Real Alternative allows avisynth to read rmvb files via the directshowsource method, which in turn allows these to be passed to any of these encoders.
Read my blog here.
NERO7 HELP ! Burning 2 files to 1 dvd5
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 12th Jun 2010, 01:13 -
help sound syncing probs usig Nero7
By polbol in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:19 -
AVI to DVD with Nero7 problems
By Cartoonheaduk01 in forum Authoring (DVD)Replies: 2Last Post: 9th Oct 2007, 12:06 -
Date in label field in Nero7
By colorbars in forum ComputerReplies: 0Last Post: 3rd Oct 2007, 03:34 -
New Asus DRW-1814BLT Sata 18x Burning slowly Nero7
By DAVE440 in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Sep 2007, 01:16
