I'm wondering if anyone has any experience with the pulldown option in CCE 2.70.
I normally use PullDownBatchFE after I've encoded my files. I'd love to cut that step out and just use CCE for that function, but I'm wondering if there is any quality difference between the two? Or does it really not matter when it comes to this? Any help is appreciated.
I use the pulldown in CCE 2.70.x and have seen no ill effects or anyhting to make think it is different or inferior to DGPulldown. I still use DGPulldown from time to time, but encodes of 23.976 material out of CCE use CCE's pulldown.
Read my blog here.
I've always used pulldown.exe but since DGPulldown hit the scene I've been using that instead.
I was not aware of CCE having this function built-in ???
I mean we are talking about encoding a 23.976fps source in CCE then applying "pulldown" so it plays back correctly on a DVD player showing as 29.970fps instead of 23.96fps.
Right?
Oh duh LOL I think I'm using an older version or something. I dunnoOriginally Posted by guns1inger
There was quite a change between the older 2.66/2.67 and 2.70. Interfaced changed, a resize ability was added (which I don't use) and a few other things. I actually prefer the oler interface for the advanced settings - seemed to make more sense. The other changes are welcome though.
Read my blog here.
hey guys
EDIT:
nevermind i was doing some more testing and i think the difference im seing isnt related to the pulldown part of it ...i think its my codec
thanks
-nomad311
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 11:45 -
question about 25 to 29 frames pulldown
By mazinz in forum Video ConversionReplies: 2Last Post: 15th Jul 2009, 13:58 -
CCE Gui Question.
By Maikeru-sama in forum ProgrammingReplies: 1Last Post: 11th Jun 2008, 20:42 -
AC3 and CCE Question
By Maikeru-sama in forum Video ConversionReplies: 6Last Post: 9th Jan 2008, 18:18 -
A question about pulldown
By Talayero in forum DVD RippingReplies: 8Last Post: 7th Sep 2007, 13:37
