Hello I have a question, I am trying to transfer some footage to VHS to DVD via video capture unit. Here is my question. I have seen about 1 hour and 45 minutes of footage on DVD that only took up about 1,200 mb and the quality was pretty good. What program can I use to do the same? The software that my video capture unit came with record the minimum bit rate of 4.0 kbps and 1 hour and 45 minutes will practically take up the whole DVD. Is there a program that I can use that will allow me to record at a lower bit rate and still get decent quality?
What capture card/device are you using and what software are you using?
Need to know that first before I or anyone else can give proper advice.
- John "FulciLives" Coleman
P.S.
Let me say this much though. For a VHS source you can use what is called Half D1 resolution (352x480 NTSC or 352x576 PAL) along with a video bitrate of approximately 3000kbps ... this will allow an audio bitrate of about 256kbps (more than good enough for 2 channel stereo audio if using AC-3 format). This will fit about 3 hours onto a single DVD recordable."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Hi John! Thanks for your reply I am using an adaptec VideOh! capture device. And the software that it came with is a basic program call Sonic MyDvd. But I also have Cyberlink power director 5 installed too. Im fiddling around with power director and I cant seem to find the settings to do that when I record, Its recording about 40 mb a minute.
I don't know much (really nothing) about your particular capture device but in my last post I gave a guide as to the things you would need to do in general.
Would be best if you could capture to an AVI format first using HuffyUV or PICVideo MJPEG but I don't knwo if your capture card is capable of that or not.
I think you'll have to switch to 1/4 D1 (352x240 NTSC, 352x288 PAL) if you want to squeeze nearly two hours of video into 1.2 GB. Unless your video is really dark and has no motion.
Bit Rate Vs Quality
By kashif71 in forum Video ConversionReplies: 20Last Post: 21st May 2010, 01:19 -
DV to h.264 for live streaming at low bit rate?
By VidQues in forum Video ConversionReplies: 1Last Post: 22nd Mar 2010, 08:56 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Is low bit rate mpeg2 (1200kbps) compatible with all DVD players?
By jimdagys in forum Newbie / General discussionsReplies: 7Last Post: 18th Jan 2008, 08:49 -
Is higher bit rate = better quality??
By imdaman in forum DVD RippingReplies: 5Last Post: 13th Sep 2007, 08:37
