My problem here is this:
I need to convert and burn multiple RMVB files onto a 4.7 GB DVD so that I can properly watch them on tv. Using a full version of dvdsanta version 4.00, I was able to convert the multiple files into compressed dvd files... However, as dvdsanta continued to convert and compress the multiple files i wanted to fit on one dvd (5 in total), the audio gradually went out of sync (when I went back to check the vob files it produced --> the first one was ok and as i checked the 2nd, 3rd, 4th and 5th vob file, the audio was starting to get out of sync more and more as the video progressed). I then used Nero to directly burn them onto dvd. This worked and I was able to view it on a dvd player at home. But the audio issue is an annoying one. Can anyone provide a clear solution for this?
(i'd still like to convert and fit multiple rmvb files on to a 4.7 gb dvd)
thanks in advance...
Well, DVDSanta being a commercial product, their support department maybe as some clue?
/Mats
Audio video synchronization problem?
By antonymaheshca in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2011, 05:26 -
Synchronization problem converting S-video to computer
By mtolesen in forum Video ConversionReplies: 4Last Post: 28th Apr 2010, 08:05 -
Audio synchronization problem when re-encodingwith StaxRip...?
By Stb1990 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 22:42 -
dvdsanta problem
By bountylord in forum Newbie / General discussionsReplies: 10Last Post: 13th Jan 2008, 09:57 -
Newbie question: Problem with synchronization
By ffabioo in forum SubtitleReplies: 2Last Post: 15th Jul 2007, 17:40
