I discovered that you couldn't mux a Video File with a LPCM audio file using TmpgEnc Plus or other software iv'e tried.
So i decided to use Tmpg Author 1.6 to do it.
This is how:
Click on create a new project, add your video m2v Video file or vob.
In the video section above you'll see the file you just added.
Then you add your LPCM file in the audio part below (which will overide whatever audio is with your video above, if there is any).
Then you bypass the menu precedure by selecting no menu, then output the file to a your selected folder. If you want, you can edit the video in the chapter cut section before output begins. Because you are outputing one Video or Vob only, it happens very quickly....like normal multiplex in Tmpg-Enc Plus or whatever else you use to Mux and De-Mux.
Find the folder with the finished Vob and you can do what ever you want with it...render to S-vcd, vcd or keep it as the Vob to use later when producing a DVD.
I
Results 1 to 1 of 1
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 15:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 11:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
