i have some avi files.now i want burn to dvd but i want them be protected by password.Do you know some sofware allow me to set password for file and can I burn protected files ?
before asking you ,i have to rar the avi file and set password in Winrar then burn to DVD.but it takes me much time.please help me.thank in advance
yea, with compressing the files you wont really gain anything as far as compression, so just set it at the lowest possible settings and let it rip.....
I'm not sure what you want, but you could use this program and keep any files on a dvd and password protect them. It's very secure and may be what you need
http://www.cypherix.com/"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
There is a simple method for DVD-video using hidden buttons and menus, requiring a sequence of numbers to be pressed to play. It is easily bypassed by anyone knowledgable, but will keep the average user or most children from being able to play it.
Your current method is much more secure but not standalone-compatible.
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 19:35 -
Need to supply "File Type" and "Mime Type" info for MKV file
By oneking in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2012, 04:31 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
