i want to convert this mpg to dvd ready mpg through tmpgenc xpress.
should i encode this to 352x480 or 720x480?
video bitrate?
i dont want to mess with the audio at all if that's possible.
thx!!!!!!!!!
File Size: 432,250,880 bytes
--- Video Information ---
Video Codec Name: MPEG-2
Duration: 00:23:18
Video Bitrate: 1556kb/s
Bits / Pixel: 0.199
Resolution: 544x576
Frames Per Second: 25.000 <-------
--- Audio Information ---
Audio Codec: MPEG-1 Layer 2
Audio Bitrate: 192kb/s CBR 48000 Hz
Audio Channel Count: Stereo
576??? Isn't that pal????
Yep your frame rate is 25fps. That is PAL.
You have to do the pal-ntsc conversion.
There are guides here for that.
Try 704x480. That is legal dvd spec and won't stretch it more than you need to.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
thx, what about the audio? can i isolate it without losing quality and just load it in tmpgenc dvd author?
virtualdub-mpeg2 can be used to demux the audio for use later.
Read my blog here.
But then as you haven't filled in your location we have no idea if you are in PAL land or NTSC land. If in PAL land all the answers you have received so far are totally wrong.
To keep it as PAL, just re-encode at 352 x 576 with a bitrate of around 3500 - 4000 kbs.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 19:27 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
MKV VIDEO CONVERSION, problem with the quality of the output file.
By pay1000 in forum Video ConversionReplies: 11Last Post: 25th Jun 2008, 03:46 -
maintain quality output file after cutting video
By karebo in forum EditingReplies: 14Last Post: 24th Feb 2008, 06:47
