I have a tuner/capture card with the conexant 878 chipset, and philips tuner, card is here http://www.supergooddeal.com/ProductDetails.asp?ProductCode=TTOM878A&Click=1
The issue I am having is, when I hook my cable into the coax, the reception is black & white, and fuzzy. If I hook a TV into the same cable, there is no problem. Any ideas on this issue?
Thanks,
Nickolas
Nickolas
THat sort of card's been around it seems like forever.
Not normally a prob, so personally I'd suspect a prob with the cable used (try another?), the tuner setup (make sure you selected correct country etc.), or software (use the latest, &/or consider freeware drivers -- think there's one or two projects offering them).
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 16:51 -
Cap Card Editing Issue?
By Evas1on in forum Capturing and VCRReplies: 7Last Post: 7th Jan 2010, 12:25 -
Card Reader: Wire issue?
By beavereater in forum ComputerReplies: 3Last Post: 15th Dec 2009, 05:11 -
SCANDISK SD memory Card Format Issue
By Johnnylee_hang in forum Off topicReplies: 5Last Post: 3rd Feb 2009, 18:33 -
Asus My Cinema P7131 Hybrid Capture Card - No Audio or Digital Reception
By Duchess in forum LinuxReplies: 10Last Post: 5th Jul 2007, 07:55
