Okay, as promised earlier, here are the settings that I am using for DIVX 4.12 and converting to mpeg2 SVCD. This is beautiful.... here are the settings for DIVX compression:
Variable bitrate mode = 1
Performance/quality = slow
Output VideoStream = 4441
Maximum keyfram interval = 300
Max CPU usage = 100%
Default Postprocessing level = 2nd notch
Maximum Quantizer = 9
Minimum Quantizer = 4
Rate control averaging period = 10000
Rate control averaging period = 600
Rate controldown/up averaging period =
Encoding quality = 75%
VirtualDub set to 23.9FPS
Resolution set to 512x384
Using YVU12 format
Audio PCM 44,100Hz/16Bit mono, 86KB/s
I used this to burn a SVCD using KingViper Template. It came out beautiful, no frames dropped..by the way I also utilized 3:2 pulldown in the template because the capture was at 23.9FPS. This way it was converted to 29.7FPS utilizing the 3:2 pulldown. The variable bitrate was about 800 or so on the template. I was able to capture an entire movie by utilzing DIVX compression...movie was almost 2 Hours/120min. Came out excellent.
Results 1 to 1 of 1
Divx multipass encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2009, 13:31 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 20:28 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 12:30 -
DVD to DivX encoding?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 13:33 -
Cut Divx without Re-encoding
By kman22 in forum EditingReplies: 8Last Post: 26th Nov 2007, 19:39
