how do i rip the subs off dvds. can DVD shrink rip them?
(if not)
if i rip the DVD to the HD with DVD shrink (with SUBs in the DVD)
then i use TDA to make a mpg (DVD format) will the SUBs be in the mpg and all i have to do is activate the subs? if you can do this how do i activate the subs?
TDA doesn't support subs, you may need DVDLab Pro for this.
Anyways, why are you using TDA after DVDShrink? -
im not going to use TDA to make the Menu. i just used TDA to make a mpg. i will be using DVD lab pro to make the menu and subs. i just cant seem to get the subs off the dvd so i can use them in DVD lab pro. another probelm is that i will be cutting scenes of of the mpg using Mpeg Video Wizard, so some of the sub titles will also will have to be removed. i should have said this in my first postOriginally Posted by NormaJ
how can look at the subs and remove the subs of the scenes that i cut out of the movie, so all the sub will be right with each scene in the movie?
Ok. You can extract the subs with Subrip from VOB files. For editing them I would suggest Subtitle Workshop.
Regards
Forced subs on HD-DVD rip
By jlchavis0844 in forum SubtitleReplies: 6Last Post: 19th May 2010, 08:40 -
How to rip subs (2)
By Jomapil in forum SubtitleReplies: 10Last Post: 31st Oct 2008, 21:01 -
how to rip subs
By aruwin in forum SubtitleReplies: 1Last Post: 26th Oct 2008, 02:25 -
How to rip DVD with subs always on
By paws in forum DVD RippingReplies: 2Last Post: 3rd Feb 2008, 14:18 -
Green subs appears on DVD but even when I rip it, on PC i'ts white!!!
By cemman in forum SubtitleReplies: 3Last Post: 21st Jun 2007, 15:57
