The program crashes when I press the DVD Play button to identify the chapters. This is the main reason for me using the program this time. Installed version 971 and crashed, then 96 also. May I try 95?
If all you want to do is identify chapters, would Chapter-X-Tractor work? Pgcdemux will also spit out a cell times text file. If you want to view the vid at cell start, can do that when setting chapt in most authoring apps, or VobBlanker can do it with DVD layouts.
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 16:54 -
problem getting ripped dvd to play in my standalone
By rmb3 in forum DVD RippingReplies: 7Last Post: 25th Jul 2008, 04:16 -
Samsung HT-P1200 DVD-R problem - PLAY PROHIBITED
By Fricas in forum DVD & Blu-ray PlayersReplies: 49Last Post: 1st Mar 2008, 13:19 -
Menu swapping with IfoEdit - Problem solved
By Bingo-days in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 03:07 -
LG RH277H play DVD-9 problem
By Horus in forum DVD & Blu-ray PlayersReplies: 7Last Post: 14th Aug 2007, 01:11
