I'm trying to do a simple authoring for a presentation in school.
i´m authoring with DVD-labPro.
The intention is to put a 3min movie playing while collegues wait.Thats why i want it to play in a infinite loop.
At any time i should be able to put the 2nd movie playing, with out using menus or buttons.
Is this possible?
Could anyone help me?
Thanks.
Results 1 to 10 of 10
Originally Posted by guns1ingerWant my help? Ask here! (not via PM!)
a hidden button is a possibility, thanks for the help.
But motion menus only allow looping for 1 min. The movie i want to loop has 3 min.
Is there any command that i can give to first movie?
I wish it colud play in loops 'till everybody is in place, only them (with the hidden button) i start the main movie. -
Why 1 minute? I use DVD Workshop and routintely have menus that loop for around 3-4 minutes. I even have them auto-play the first title if nothing is selected after 5-10 loops, if I want.
Thank you both for your hep.
I allways thought that DLP had a time limitation in motion menus, but the only limitation here was mine.I usualy use it with 1 min. -
humurous guns1inger.
want to reveal?
What do you mean by 'various states'?
Do you use dvd-lab pro? -
IYep, DLP. Create button and link it to an asset. Now select it and look at the properties down the right-hand side. Click on the Link tab and you should see a field called Button Visibility. It is a drop-down list of options. Have a play there. You might also have to change the transparency of the highlights.
If that doesn't work, you can follow the blue budgies advice and stick it in the overscan.Read my blog here.
Create your menu and drag your 3 minute video and audio to it. In menu properties on the right, under menu playback, change duration from "a/v" to "inf". This will cause your menu to loop.
Create a button anywhere on the menu and link it to your movie. In menu properties under Button Link, change button visibility to "invisible all".
Now your mini movie will loop until you hit play, as the invisible button will be the only one highlighted and the only one playable.
simple sw to re-author Blu Ray
By Oktober in forum Authoring (Blu-ray)Replies: 2Last Post: 16th Jul 2010, 04:24 -
Author AVCHD with simple text-based menu?
By litmus in forum Authoring (Blu-ray)Replies: 1Last Post: 28th Feb 2010, 17:52 -
How do I author a simple dvd for episodes?
By exillion in forum Authoring (DVD)Replies: 11Last Post: 8th May 2008, 11:25 -
Creating simple "movies" with simple graphics?
By uniks in forum Newbie / General discussionsReplies: 11Last Post: 24th Mar 2008, 01:25 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 14:33
