I have a video that a co-worker asked me to convert to a dvd so he can use it in some presentations at work. I tried to open it in TMPGEnc, but it said that it wasn't a recognizable format. I'll author it in DVDLab. Tried VDubMpeg2 - no luck. Checked it with AVIcheck and Gspot. Here's what it gave me:
1920 x 1080i HD mpg Cyberlink Video/SP
1 audio stream AC3
What do I need to use to convert it so I can author it to DVD?
Thanks for any and all help.
Snake
Try opening it with virtualdub-mpeg2. You will have to resize it down to DVD spec resolution, frameserve to an encoder to get the bitrate down, then author it. Assuming you need a DVD at the end of the process.
Read my blog here.
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 06:46 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 01:26
