What resolution was the original ?
Generally, the original avi is smaller than DVD resolution, so it has to be resized up. If not done with care, this will result in a softer image. It will also enhance flaws that are present in the original, but which you might not be noticing. DivxtoDVD then re-encodes the avi to mpeg2, usually at a fairly low bitrate. This may further enhance any existing flaws, as well as possibly introducing new ones. The video may also have the IRE levels adjusted, lightening the video and showing up flaws in the darker areas that you might not have seen.
Can you fix this ? Not with DivxtoDVD or any one-click program. Using avisynth, a good resize algorythm such as Lanczos or Lanczos4, the blockbuster and ashrp filters you can reduce the existing flaws without introducing new ones. Encoding with a good encoder at the correct bitrate will preserve the work you did with the filters. Finally, accepting that the original is flawed, regardless of what you might think after watching it in VLC. This will get you an output that is 100% better than DivxtoDVD. Will it be perfect or DVD quality - probably not. Your source isn't good enough to allow for that.Read my blog here.
Or, it could be an interlacing issue - the original DivX is deinterlaced, whereas the DVD version is interlaced - DVD's always look like crap on a computer (compared to a DivX/XviD) because of interlacing, imo.
You have reencoded. Just that takes some quality toll, compared to the source.
/Mats
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
Youtube picture quality
By Juc1 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2009, 20:36 -
Question regarding DVD picture quality
By Neutral-Sage in forum Authoring (DVD)Replies: 7Last Post: 5th Nov 2007, 18:34 -
Picture Quality Question on made DVD
By Superstar24 in forum Newbie / General discussionsReplies: 24Last Post: 26th May 2007, 00:35 -
picture quality
By nexous in forum RestorationReplies: 4Last Post: 18th May 2007, 04:03
