  1. Hi all
    I have been trying to burn 5 tv shows each 42 min long and 360mb in size in avi format to a dvd I use nero 7 ultra edition and the menus and picture all come out okay apart from a slight judder (other post on here), but I have now got a prob with the audio the first two shows are fine then the audio goes out of sync for the next show then is fine again untill half way through the one after that, So is there a better way to do all this eg. best prog etc or can the prob be fixed in nero? willing to learn and dont expect short cuts. Any help would be greatfully recieved
    Mage00
    There are no stupid questions, only stupid people.
    Apr 2004
    Miskatonic U
    I suggest you don't double post - it is frowned upon. I have answered your first post, so let's keep it over there.
    Read my blog here.
  3. Thanks for your prompt reply will try all the things you suggested, I did delete the previous post but not quick enough sorry. thanks again for the advice
    mage00
  4. Also mage00, can you put in a title that is more descriptive of your problems next time?
    It assists forum members to locate posts they believe they can help with. Thanks
    /Moderator Offline
  5. Will do, still on a learning curve.
    thanks
    Mage00
