  1. What would be the easiest, most efficient method for me to go about taking a catv signal captured on my conexant capture card, stream it to the internet in a private (pw protected) stream that only I 1 user can access. my upstream speed is 714 kbps.
    Basically what I am wanting to do is have my cable captured by my card, and be able to go to a remote location (work) and view it, if possible also, change the channel remotely.
    Whats the best way to go about this?
    Thanks,
    Nickolas
    Nickolas
    Nov 2005
    There are a few projects online you can check out, use window media encoder, &/or there are a few retail products you can look into.
