Hello there,
I have a 42 inch HD TV in my main living room (small 2 bd apt, 1 story). In the next room (office type) I have a P4 Dell desktop with always on Broadband connection.
Most of the times I have to get up to surf the web or do something in the computer but ( and I may be fantasy thinking) I want to see the possibility of controlling the computer remotely or maybe surf the web using my TV using the broadband connection in the apt. Also I want to play in my tv ( and i know this is the most doable) files stored in my pc like mp3's or videos.
What do you guys suggest i get?
you could get an IO Data to play the videos .. they work great btw for this ...
surfing the web on a plasma will look like crap though ...
for the most part ..
you could just get any RF type keyboard and mouse (not IR) to do so though ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Dvi from computer to hdmi to 65 inch panasonic plasma hd
By jplot in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2011, 18:56 -
New to Plasma/LCD/LED. Should I buy this plasma screen if I'm a gamer?
By Hank Kinsley in forum DVB / IPTVReplies: 4Last Post: 1st Nov 2010, 15:33 -
Proper PAL-to-NTSC conversion, and viceversa
By jeanpave in forum Video ConversionReplies: 15Last Post: 14th Jul 2009, 20:20 -
Pioneer Plasma PDP-434CMX & Panasonic DVD-S100EG-S sync problem?
By stieven in forum DVB / IPTVReplies: 2Last Post: 18th Feb 2008, 08:26 -
Are you able to author ripped bluray as hddvd and viceversa?
By yoda313 in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2007, 21:04
