Hi there
I will admit I am completely new to all of this. I have a Xvid video that I want to convert so that it can be used in a standalone DVD player. It does not support Xvid, so I have no other option.
I used TMPGenc Plus to convert it, by using the guides on this website and the resulting video is OK (except it's fullscreen?) but has no audio.
Read the TMPGenc problems sticky and downloaded VirtualDub and following yet another helful guide I converted the audio (MP3) to a wav file (a whopping 1093Mb).
Using TMPGenc, I close the wizard, browse to the video, browse to the audio (now a wav file) and use the preview option and the video opens fine but still there is no sound? I don't want to proceed any further without some help.
Many thanks for your replies.
Cheers
Results 1 to 13 of 13
[quote="guns1inger"]It sounds like you are on the right track. Hvae you listened to the wav file, to make sure it has something in it ?
Hi there
Yep, the wav file contains all the audio to the video 100%. If it plays as a wav file OK, will it work when I use it as the audio stream in TMPGenc?
Also why don't I get any audio when I use the Preview option in TMPGenc? Or does it not play sound? Not sure because this is the first time I've used it.
Cheers -
Originally Posted by guns1inger
How do I do that and then watch it to see if the audio is working? Also what program do you use to convert Xvid / Divx to DVD?
Cheers from Oz -
Hi there
yep, I'll try that tomorrow. But I would like to ask another question before I sleep.
I just loaded VirtualDub 1.6.12 on my other computer running Win98SE and it has the Xvid codec installed. I opened the video I referred to in my earlier post in GSpot and it states the codecs are in installed.
On trying to open the same video in VirtualDub I receive this error message:
"Couldn't locate decompressor for format XVID (unknown)"
"VirtualDub requires a Video for Windows (VFW) compatibile codec to decompress video. DirectShow codecs such as those used by Windows Media Player, are not suitable"
The video opens and plays in my crappy Win98SE WMP?
How can I get this to work?
Thanks again. -
Use fourcc code changer on your AVI and patch it to DIVX.
/Mats -
Originally Posted by mats.hogberg
Many thanks for your help. I tried that and now when I go to open the video the error message is the same except it says Divx and (Divx4+) instead of unknown.
So I still can't get it to work.Any other ideas please.
Cheers
EDIT: I just changed the fourcc code from xvid to mp42 (thought I'd give it a go) and it opened! I don't know why (and I would like to for my learning experience) but at least it now opens. -
The fourcc tells the app what codec to look for and use to decode a particular AVI. Many codecs handles lots of different "subformats", so if you're lacking the exact match (or is it's incompatible in any other way) some other codec might well handle your AVI as you've found.
/Mats -
Hi again everyone.
Did not want to start a new post but could anyone out there suggest a DVD Authoring program, maybe similar to TMPGenc DVD author but that works in Win98SE.
Many thanks
Cheers -
Doesn't TDA work with W98?
Well, another reason to upgrade...
AFAIK, no other autoring app provides the ease of use/output quality TDA gives.
But you could always try GUI For DVDAuthor which seems to work for 98/me
/Mats
Converted video (mp4): audio out of sync
By darknezx in forum Video ConversionReplies: 4Last Post: 22nd Mar 2011, 02:25 -
Converted audio shorter than video
By rjc7394 in forum AudioReplies: 0Last Post: 15th Jun 2010, 00:14 -
No audio with converted video files
By TomLJ in forum Video ConversionReplies: 10Last Post: 7th Oct 2009, 14:47 -
Converted video has no audio
By franks65 in forum ffmpegX general discussionReplies: 5Last Post: 2nd Sep 2008, 08:43 -
no audio on converted video
By beanosirra in forum Newbie / General discussionsReplies: 5Last Post: 12th Jun 2007, 13:19
