i have read a few forums concerning mkv files and how to convert them. i have tried "avi2dvd" but when asked to select an audio stream none were available.. so i was then put onto a program called "mkvextractgui" so i put my mkv file thru this but i ended up with 2 files.. Track1.rmvb and Track2.ogg which when i click on track1 just plays the video with no sound if anybody could come up with any answers using either program (or any other method) on how to get this file onto a disc so i can watch it on tv i would be very grateful tia
Track1.rmvb - is your video (format used by RealPlayer)
Track2.ogg - is your audio (Open Source format for audio)
You used MKVExtract GUI to split the two apart (you took the two separate parts out of the *.MKV container)
Your still on track. You now need a guide to follow that deals with separate audio and video.
Both tracks may need to be converted to other formats before they can be seen by Avi2DVD.
convert the track2.ogg to wav...search for ogg to wav. and use wav in avi2dvd.
or try avisynth the mkv to any encoder, https://forum.videohelp.com/viewtopic.php?t=284288 or https://forum.videohelp.com/viewtopic.php?t=289872 -
OggDrop is simple. It's usually used to encode to *.OGG from *.WAV but it can also decode from *.OGG to *.WAV.
http://www.rarewares.org/dancer/dancer.php?f=44
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
how to join mkv.a and mkv.b files
By sumeshkri in forum EditingReplies: 1Last Post: 5th Apr 2012, 20:56 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 02:53 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 13:10 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 01:45
