Hi
I am using ADS DVDXpress and have installed capwiz but when I open the program it wont recognize the capture device. The error message is: "chpwiz unable to detect USB capture device. Check power light and secure all cables".
The red power light is on and the power cables are secure. Also the ADS drivers show up in device managers so I think they are loaded.-----Any ideas?
Thanks.
If this is 1st time (not a prob where worked previously), is the USB port powered adequately? Some hubs, some ports on case will not always work. If this is prob., use port mounted to M/Board or powered hub using wall wart & set to power mode.
Windows 7 Drivers for VideoXpres Capwiz?
By eggs44 in forum Capturing and VCRReplies: 13Last Post: 21st Dec 2015, 14:13 -
ADS DVDXpress CapWiz drivers missing?
By CaptainChaos in forum Capturing and VCRReplies: 9Last Post: 3rd Feb 2011, 16:47 -
CapWiz doesn't see VideoXpress device
By jon davies in forum Capturing and VCRReplies: 7Last Post: 9th Oct 2010, 21:51 -
ADS DVD Xpress CapWiz Woes
By yaddablah in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2010, 11:13 -
Major Problem with DVD Xpress DX2
By AcidFMHQ in forum Capturing and VCRReplies: 0Last Post: 22nd Aug 2007, 06:02
