hi There...
I've a problem in power director 3 that I'm trying to edit some .WMV files
but as soon as I put the .WMV file in the video track to edit it...the whole
software(I mean power director 3)freezes and exit by it self...
and for your knowledge I've tried another type of files like .mpg or .mpeg
and even some other.wmv's and it works perfect..but many other wmv's didn't..
so what can I do???
THANKS IN ADVANCE..
Video files with the same compression or type can be quite different internally. If you can figure out the difference between those that work & those that don't, might be able to change the ones that won't. For example might be audio track, which is easier to change then video.
Otherwise, only cure I'm aware of is to run them thru wmencoder or convert to another format. -
try dragging it into windows movie maker and see what happens
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 08:25 -
Play MKV files in Power DVD
By prabhakarlad in forum Software PlayingReplies: 2Last Post: 11th Oct 2010, 01:46 -
Corrupted AVI files after power failure
By Babaloo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2009, 15:58 -
Problems in different equipment with .mpeg1 in Power Point
By carlosarano in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 09:25 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
