As shown in the thread below, my TBC-3000 does not correct distortions in vertical lines caused by time base errors. Does anyone have an external TBC that does? If so, can you post some caps showing the correction it does? TIA
https://forum.videohelp.com/viewtopic.php?t=289311
I actually use both an external TBC, and a JVC vcr with TBC because the JVC's TBC will do digital noise reduction too, and prevent the vertical bending you are talking about. I am not aware of any external unit other than a VCR that can eliminate the vertical bending from VHS tapes.
vhs with vertical lines
By spiritgumm in forum Video ConversionReplies: 29Last Post: 22nd Aug 2019, 10:17 -
Bizarre vertical lines
By Asterra in forum Capturing and VCRReplies: 55Last Post: 17th Apr 2011, 22:46 -
What if TBC doesn't fix the vertical jitter?
By moxiecat in forum RestorationReplies: 8Last Post: 1st May 2009, 07:31 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 09:29 -
vertical lines in 2.5
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 23rd Jun 2007, 15:53
