Results 1 to 23 of 23
    Dec 2005
    Alright i have The Stealers vs Colts Football game recorded in DVD quality off my ati shit and its saved as NFLplayoff.mpg and its about 9 Gigs and i am gonna have 2 put it on a dvd how do i do this..
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    author it and burn it to a dvd there are guides for that you can find them by clicking on the green author link on the left side of this page if you don't want to use two disks then you can shrink it to fit afterwards with dvdshrink but you would have been better to capture the footage to the correct size in the first place
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Do you want it on one DVD ? SL or DL ?
    Or do you want to split it onto 2 SL DVDs ?
    If in doubt, Google it.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If you don't want to transcode/reencode (=decrease quality) you either have to use a dual layer DVD, or cut the mpg in two (womble mpeg vcr).
    /Mats
  5. Member rhegedus's Avatar
    on the jazz
    How long, in minutes is the whole thing (with/without half time crap)?
    Regards,
    Rob
    Dec 2005
    about 130 mins because i cut half time out by pausing it and most of the commercials so i just wanna Eather fit it onto a dvd to watch on my dvd player sometime or fit onto a data disk so i can watch on bigscreen through my s-video on my other computer.
    Dec 2005
    the thing is its 9.36 GB (10,057,992,192 bytes)
    and wont fit on one dvd and i need 2 split it or something
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Reencode it down.130 min gives you >4400 kbps to play with (given 224 kbps audio) 9.36 GB for 130 min approaches max allowed DVD bitrate - overkill in most cases.
    /Mats
  9. Member Cornucopia's Avatar
    Check and see what the audio is...maybe it's PCM! You might could save a whole lot of space by converting the audio to med/low bitrate mp2 or AC3.
    Dec 2005
    but see thats what i need help with i dont know what im doing :- \
  11. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
  12. Member Cornucopia's Avatar
    Evan7, get Gspot and open your file(s) in that. See what the bitrate for the video is, see what the frame size is (hopefully 720x480), and see what kind of streams the video and audio are (usually MPEG2 for video). The audio probably shows (L)PCM (or some variant spelling) or AC3 (aka Dolby Digital) or DTS or Mpeg1Layer2 (or similar) or Mpeg1Layer3 (possible for MPEG, but not allowed for DVD). If it's the 1st one, you can reap some file savings...
    Get TMPGEnc and demux your MPEG stream to elementary video and audio streams.
    Then, you could use TMPGEnc again to convert that LPCM stream (probably shown as a WAV file) to mp2.
    Then, use TMPGEnc again to re-Multiplex the video and the new audio to a new MPEG Program stream.
    Then author with the new muxed stream file.
    I know that's not step-by-step, but there are a number of guides here for each of those steps. Just search for them...
    Dec 2005
    i used gspot but im not 2 familer on how 2 use it but i opened file and in most of what u want is says n.a. only thing that showed up was the size
    1,400 MB (or 1,433,650 KB or 1,468,057,600 bytes)
    path
    D:\Temp Anything\NFL Playoff (Jan 15).mpg
  14. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    get the latest beta of G-spot. The version you have can't read mpegs files correctly.
    Read my blog here.
    Dec 2005
    Container
    MPEG-2 Program Stream << { 1 vid, 1 aud }
    Sys Bitrate: 8586 kb/s VBR
    Audio
    Codec: MPEG-1 Layer 2
    info: 0xc0:48000Hz 224 kb/s total (2 chnls)
    Video
    Codec: MPEG2_Video
    stat: Codec(s) are NOT Installed
    Length: 02:38:40
    Frames: ~285,297
    kbps: 8000
    Qf: 0.772
    Pics/sec: 29.970
    Frms/sec: 29.970
    Flds/sec: 59.939
    Frame: 720 x 480
    FAR: 1.500 (3:2)
    PAR: 0.889
    DAR: 1.333 (4:3)
    1. None, already DVD format
    2. None, already DVD format
    Thats all i got now what?>
  16. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Well, it's mp2 audio - not much to tinker with there.
    Either reencode @4400 kbps, or author as is to HDD, then shrink the output down to DVD5 size with DVDShrink before you finally burn it to DVD disc.
    /Mats
    Dec 2005
    See iuno how to do that reencode? or HDD mabe u have aim or msn or somthing and we can chat on that if that would be easier to go through this stuff
  18. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    No really - I don't do "holding hands"!
    Just author it with let's say TMPGEnc DVD Author, ignoring all warnings that the final DVD will be too big.
    Don't open the burn tool after the authoring process. Just quit TDA.
    Open DVDShrink, click the Open Files button, and browse to where TDA wrote the authored files.
    Set Shrink to output ISO.
    When DVDShrink has finished, burn ISO with ImgBurn.
    Done.
    /Mats
    Dec 2005
    ok i got DVD Aurthor now i click creat new project then add file and i opened the nfl playoff and it says this
    *The video sequence header is incorrect.
    A video sequence header is necessary for every GOP in a standard DVD.
    Dec 2005
    Anybody know?
  21. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You need a sequence header for every GOP.
    There's a guide in the guides section that deals with MPEG-1 using TMPGEnc Plus, but I think you could adapt it for MPEG-2. Either that or one of the MPEG Tools like VideoRedo or Restream might be able to help. Forum search "sequence header" and you might get some good results.
