Hi,
I have already ripped the DVD with DVD Shrink and the VOB files
are inside VIDEO_TS folder on my hard drive.
My question is:
Is there a difference between burning a DVD as a DATA DVD and creating the VIDEO_TS folder vs. choosing the DVD Video project
in Nero and dropping the VOB file in there ?
Results 1 to 12 of 12
Yes. DVD Data will preserve your Video_TS folder as a sereis of files, but it won't be playable in most DVD players as they will see it as just a set of files, not a DVD. Using DVD Video you get the correct file structure and it will be recognised as a DVD Video, not a plain data disk.
Can I suggest that if you are using DVD Shrink you also install DVD Decrypter, and when you backup using Shrink, choose the Create ISO and Burn with DVD Decryper option. Then you don't have to worry about these matters.Read my blog here.
Originally Posted by guns1ingerIf in doubt, Google it.
UDF or UDF/ISO bridge, yes
Thanks for the replies.
I would like to temporarily rip the DVD to my hard drive and watch from my hard drive, and if I decide
I like it I will burn it. From the replies above the best solution is ripping it as an ISO. After I have the ISO on my hard drive is it possible to play it ?
Is there any tool ? -
Now, THAT'S a good question...
The DVD-Video application format is a Data Disc, but with particular constraints:
1. Filesystem must be (micro)UDF v1.02 (which may be bridged with ISO9660)
2. Files must be contiguous (no breaks/fragmenting)
3. Files must be recorded in a particular order (VIDEO_TS.IFO 1st, etc)
4. Files (in VIDEO_TS or AUDIO_TS) must ALL be less than 1GB
5. Files must have no "Default Operating System Designator"
6. Only certain files are allowed in the VIDEO_TS folder (authored files)
7. The VIDEO_TS folder, AUDIO_TS folder, and any contained files must have set the "High Priority flag" ( IIRC ? )
8. Disc should be recorded single track, single session
9. Disc must fill at least 1GB (if data isn't that long, extend the leadout)
...there may be other requirements.
Standard Data DVD discs can be created that don't follow all those requirements and still work fine as data discs, but then that loses compliancy/compatibility for DVD-Video.
You could create a standard data disc and add the files and IF your burning application could precisely control for all those requirements, then you would be making a DVD-Video compliant data disc. But it's just so much easier to use an app that specifically supports the DVD-Video spec.
Scott -
Originally Posted by Cornucopia
Let's say you have a disc and want to determine whether it is truely compliant. What would be a good way to do it? What applications would be usefull? -
The corporate/business way to do it:
Get a copy of DVD-Video verifying software (from Philips, Eclipse and others). Cost=$$$$. There was a thread about this just the other day.
They'll let you know if all your ducks are in a row.
The prosumer/anecdotal/experiential way to do it:
Use ISOBuster to veryify session/track info and sector-by-sector file order. There are other softwares that can tell you UDF v.#, etc. But the best way to tell is by getting some REALLY PICKY settop players (esp. older ones) and trying them in there. If they play correctly there, it's compliant enough!
difference between burning DVD-4,7 GB and DVD-8GB
By michcio in forum DVD RippingReplies: 3Last Post: 2nd Jul 2009, 10:56 -
Difference between VCD and DVD?
By brandon334 in forum Newbie / General discussionsReplies: 6Last Post: 25th Apr 2008, 10:30 -
what is difference to + and - DVD-R and RW?
By snadge in forum DVD RippingReplies: 2Last Post: 27th Feb 2008, 12:14 -
What’s the difference between the DVD Shrink3.2 and Rebuilder?
By coody in forum DVD RippingReplies: 5Last Post: 27th Feb 2008, 11:17 -
HD-DVD players. What is the difference?
By mmcguigan in forum DVD & Blu-ray PlayersReplies: 18Last Post: 19th Feb 2008, 11:43
