I bought a DV capture card with a cable and a Ulead disk for like 12.00 on ebay. How do I know what kind of card I got? I know its probably the bottom of the line, but I can't figure out even what kind it is. Anyone?
Most any PCI card has a FCC id number on it. You can check on a site similar to this: http://www.driverzone.com/fcc_id_search.htm and you should find a link to the manufacturer. Go to their site to look for drivers if you need them.
In general a Firewire card doesn't need drivers. The OS, XP in particular, will apply a generic driver and it should work fine. Just plug it in and try it. I generally use WinDV for Firewire transfers to the computer.
What kind of screen should I get?
By vidds in forum Newbie / General discussionsReplies: 17Last Post: 13th Jun 2011, 20:49 -
what kind of protection is this?
By AaronDude in forum DVD RippingReplies: 0Last Post: 6th Jun 2011, 17:34 -
what is this for kind of codec.
By Cazz in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2009, 15:18 -
what kind of discs should I be using?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 4th Dec 2008, 00:15 -
What kind of gamer are you?
By yoda313 in forum PollsReplies: 21Last Post: 6th Aug 2007, 18:18
