Hi All,
I've just rebooted and the computer cannot find either my Cd or DVD drives.
Any ideas where I go from here?
Bill
Results 1 to 10 of 10
First this should be in the Computer forum.
Check your BIOS settings. If you can see them there, check the Device Manager in Windows for drive entry's. Remove any uninstalled components with red or yellow markings and reboot.
If you have a motherboard CD with drivers you might try re-installing them.
Good Luck
UB -
Moving you.
/Mats -
Nope, I re-booted three times and not only did the annoying whirring sound vanish, but the drives cam back!
Bill -
I'd say, somthing in Redmond is LOOSE!
/Mats -
Yep, I concur!
When I have built up the courage to untangle the leads etc, I'll go have a look!
Bill
Looking for best PC drives
By tpapictures in forum Blu-ray RippingReplies: 26Last Post: 6th Apr 2012, 11:45 -
media drives
By c-raig in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2010, 05:13 -
Old drives in new DVR?
By cwb in forum DVB / IPTVReplies: 5Last Post: 1st Jun 2010, 22:29 -
Hard Drives
By hardy in forum ComputerReplies: 16Last Post: 27th Jun 2009, 19:00 -
Drives will not refresh
By JWT in forum DVD & Blu-ray WritersReplies: 9Last Post: 29th May 2007, 10:29
