I was wondering what difference does it make in the output files if I use DVD decrypter in IFO mode or files mode, if I am planning to rip the output to DivX or XviD.
I know that if IFO mode is used then you can extract the program chains but this option is not available in files mode but what difference does it make down the line of conversion?
IFO Mode. If you just decrypt in file mode, there might be other stuff in the same VTS, not to mention the mess you'll make of it if it's multi-angle.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
DVDDecrypter IFO Mode - How do I know what cells belong to an angle?
By Gatlinator in forum DVD RippingReplies: 6Last Post: 26th Dec 2010, 04:03 -
DVD Decrypter IFO I
By drstew in forum DVD RippingReplies: 6Last Post: 2nd Dec 2007, 23:42 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
