Hi,
I have an iso which I would like to convert for DVD Players format. After running a web search, I found that dvdSanta can do the job. Still, dvdSanta accepts input exclusively from a CD/DVD drive. Since my file is residing on my HD, and I don't like the idea of a two-step DVD media burning, one from my HD to a DVD disk, two from this DVD disk in ISO format to DVD format via dvdSanta, I hoped to find a way to set a virtual DVD drive, copy the ISO file to it, input it to dvdSanta, and output it to a DVD media.
I tried Paragon CD-ROM Emulator, but failed either in copying the file to this virtual disk or in finding a way for inputting the file from the virtual disk to dvdSanta.
Can you suggest a way of converting a DVD ISO file to a DVD format to be burned on a DVD media?
Ran
Results 1 to 9 of 9
iso is a 'disk image' you should be able to directly burn to dvd with practically any dvd-burning software
I am just a worthless liar,
I am just an imbecil -
if it isn't a dvd-video iso then use daemon tools to make virtual drive from the iso, then convert with divxtodvd,dvdsanta,etc.
if a dvd-video iso burn with imgburn. -
Can't you just go into a program like Nero and go file->open and then browse to your ISO file and it will arrange it for you and then you can just burn?
To Baldrick,
How do I know if my ISO file it is or it isn't a dvd-video iso? All I can see is an iso extension.
Ran -
use daemon tools to make virtual drive from the iso.
or open with isobuster.
check for a VIDEO_TS folder with vob,ifo,bup files = probably a DVD-VIDEO.
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
Help Converting an ISO Image File into a DVD Format playable on DVD players
By Gradyj in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2010, 21:13 -
Converting an MPG file to an ISO file.
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Dec 2009, 22:58 -
converting BD iso to DVD
By ejjames in forum Video ConversionReplies: 1Last Post: 1st Sep 2009, 08:51 -
converting an ISO file
By janefield in forum Video ConversionReplies: 2Last Post: 24th Jun 2007, 18:20
