i have problems with Dr Dolittle2 rip ,i use smartripper-dvd2avi-tmpeg. when i make it into svcd the picture freezes 0.5sec every 10 sec -why is that?
assuming you use "movie mode" to get rid of any possible multi-angles in the movie, did u?
1) turn off all major applications while encoding?
2) did you use forced film in dvd2avi and 3:2 pulldown in tmpgenc?
3) if you turned off forced film in dvd2avi and made your rip interlaced rather than using 3:2 pulldown, make sure you select the right field order in the video source settings. if this is the case, try switching to the other field order. for me, if i make my dvd rips interlaced, only bottom field first will make my rip play smoothly. if you get the field order wrong, the rip will be very, very jumpy, like it's trying to go backwards or something.
program freeze
By mulgui in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2009, 21:03 -
mplayer freeze
By ajv in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 16:15 -
Svcd2dvd Freeze's
By gazinc in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 18th Apr 2008, 13:00 -
more dvd freeze problems
By dblake2 in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2008, 11:27 -
pc freeze up
By triggerstep in forum Video ConversionReplies: 5Last Post: 24th Feb 2008, 04:12
